brcaldwe
#1 Posted : Friday, October 22, 2010 8:11:39 AM(UTC)
brcaldwe
I have a kenmore front load stacking washer that will not drain. I have checked the hoses and replaced the pump. It is still not draining. Any ideas?
Thank you.
Joe / APP Team
#2 Posted : Friday, October 22, 2010 8:43:20 AM(UTC)
Joe / APP Team
Thank you.
BR,
We'd have a better idea if you get us a proper model number.
Anything at this point would be a guess and probably not correct.
Thanks,
:confused: :confused: :confused:
brcaldwe
#3 Posted : Friday, October 22, 2010 9:13:03 AM(UTC)
brcaldwe
model # 26-40412
item # 02640412000
Joe / APP Team
#4 Posted : Friday, October 22, 2010 10:16:51 AM(UTC)
Joe / APP Team
model # 26-40412
item # 02640412000
BR,
Still incorrect, that's not a model number either.
The Model number tab should be on front panel when you open the door
Should look something like this :
123.45678900
Please try again,
Thanks,
:cool: :cool: :cool:
brcaldwe
#5 Posted : Friday, October 22, 2010 10:32:56 AM(UTC)
brcaldwe
found it
Model# 970-c45042-00
Serial# xc51718724
Joe / APP Team
#6 Posted : Friday, October 22, 2010 12:05:19 PM(UTC)
Joe / APP Team
found it
Serial# xc51718724
BR,
We still have a prolem with that serial number, But
As best I can tell, Since you have a new pump, and it still wont drain,
I would have to suspect a loose or broken wire from the pump to the timer, or a bad timer.
That's the best we can do, until we get a proper model number so we can access the technical information and parts lists,for more accurate diagnosis and repair.
Thanks,
