gustone
#1 Posted : Monday, October 18, 2010 11:56:44 AM(UTC)
gustone
I have a maytag gemini electric range. It has a small top oven/toaster/broiler and a regualar sized bottom oven. The lower (bake) element of the upper oven does not work. If I connect the broiler wires to it the element gets hot so the problem is not with the element. Could it be the control board? How do I find out if this is the problem?
gustone
#2 Posted : Tuesday, October 19, 2010 7:08:42 AM(UTC)
gustone
After further reading, I am wondering if it could be a fuse or something similar. How can I measure the voltage from the bake switch to the element to see if there is power? If there is no power do I need to replace the control board? It is $222 on this site. A repair man I called said it would cost between $300-500.
Kenmore Elite Oven bake element not heating (Oven Repair (including Ranges and Cooktops))
by ADN140 12/16/2013 12:24:26 PM(UTC)
Bake Element not heating (Oven Repair (including Ranges and Cooktops))
by 1dog 6/30/2013 8:25:57 PM(UTC)
lower bake element not heating (Oven Repair (including Ranges and Cooktops))
by danasd 2/14/2013 12:17:32 PM(UTC)
Bake Element Not heating Whirlpool oven (Oven Repair (including Ranges and Cooktops))
by 3MTA3 11/2/2012 5:56:37 PM(UTC)
Bake element not heating up after replacement (Oven Repair (including Ranges and Cooktops))
by greatwhite333 5/4/2012 1:06:18 PM(UTC)
Whirlpool Oven - Lower bake element not heating (Oven Repair (including Ranges and Cooktops))
by dannyz 12/10/2010 12:58:34 PM(UTC)
Lower Bake Element not heating (Oven Repair (including Ranges and Cooktops))
by Shadowbyte 10/17/2010 6:18:42 AM(UTC)
Upper bake element not heating (H3 displays) (Oven Repair (including Ranges and Cooktops))
by smithmr 7/23/2010 9:55:33 AM(UTC)
Bake Element Not Heating (Oven Repair (including Ranges and Cooktops))
by DelD 7/7/2010 8:58:54 AM(UTC)
Bake element not heating (Oven Repair (including Ranges and Cooktops))
by brnjhn90 12/9/2009 2:31:56 PM(UTC)
bake element not heating but broil element heating okay (Oven Repair (including Ranges and Cooktops))
by horno 10/4/2009 8:28:00 AM(UTC)
by hdturrentine 1/19/2009 6:17:02 PM(UTC)
