RUMA
#1 Posted : Saturday, October 16, 2010 8:25:40 AM(UTC)
RUMA
ON MY DISHWASHER the scroll arrows( up and down) selections button does not move off of normal cycle...HELP
#2 Posted : Sunday, October 17, 2010 4:15:54 AM(UTC)
Replacement parts for General Electric PDW9880J00SS Dishwasher | AppliancePartsPros.com
Here is a manual although it does not actually say it covers a 9800 series it may be close. At least, it is the best I can do.
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Check to see if the delay hours key works if not then odds are there is a problem with track 11 as it is common to all 3 keys. Could be the keypad or the control board. The usual way to troubleshoot is to check the keypad with a meter if it is OK then replace the control board. Still a bit of a crap shoot but your odds are better.
May just be a dirty connector, see below.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
GE Profile Dishwasher Hums when Off (Dishwasher Repair)
by Thom64 2/7/2022 7:19:40 PM(UTC)
GE profile dishwasher PDW9980N00SS starts then stops (Dishwasher Repair)
by cfcstl 12/15/2020 8:18:18 AM(UTC)
GE Profile Dishwasher QP 47 Can't move between different Wash programs (Dishwasher Repair)
by MTHall720 3/26/2020 11:32:29 AM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 4:33:33 PM(UTC)
GE profile dishwasher (Dishwasher Repair)
by barnee72 1/14/2016 5:47:55 PM(UTC)
GE Profile Dishwasher lights up, but will not start (Dishwasher Repair)
by cjsrinivas 12/21/2015 8:06:27 PM(UTC)
ge profile dishwasher - nut water inlet - repair or replace? (Dishwasher Repair)
by dsynadinos 3/1/2014 5:22:20 AM(UTC)
GE profile dishwasher won't drain completely (Dishwasher Repair)
by nazia 2/25/2014 5:52:10 AM(UTC)
GE Profile dishwasher GHDA696Pss doesnt drain completely (Dishwasher Repair)
by jdn9580 1/11/2014 10:15:13 AM(UTC)
ge profile dishwasher (Dishwasher Repair)
by rickcallaway 11/4/2013 8:17:53 AM(UTC)
GE Profile dishwasher motor fan (Dishwasher Repair)
by saegsblair 9/19/2013 5:45:58 AM(UTC)
GE Profile Dishwasher won't drain (Dishwasher Repair)
by tms101 9/14/2013 9:47:52 PM(UTC)
GE Profile dishwasher not cleaning well (Dishwasher Repair)
by edjr 3/30/2013 4:25:14 AM(UTC)
GE Profile Dishwasher - Constant Buzzing (Dishwasher Repair)
by diydaddy 1/25/2013 9:49:05 AM(UTC)
GE Profile Dishwasher will not fully drain (Dishwasher Repair)
by springerider 1/6/2013 6:30:22 PM(UTC)
