eno2220
#1 Posted : Friday, October 17, 2008 7:02:38 AM(UTC)
eno2220
Will not fill with cold water, only hot. I checked the hose for clogs and found none. What should I do next ?
magician59
#2 Posted : Friday, October 17, 2008 8:06:18 AM(UTC)
magician59
Rank:: Advanced Member
I would check to see if water freely flows through the cold water spigot, then check to see if there is any obstruction of the valve inlet. If water gets to the valve, and there is little or no obstruction, then test the inlet valve for operation.
loma
#3 Posted : Wednesday, October 22, 2008 4:21:43 PM(UTC)
loma
I have the same problem. Cold water runs for a little bit and then stops. Nothing in the filters and the hot is fine. Hope you have better luck........I'm going to try the one suggestion I got and replace the inlet valve. I'll let you know in about a week how it went. Hope you get more help..........
libertyappl
#4 Posted : Wednesday, October 22, 2008 8:40:10 PM(UTC)
libertyappl
Change the water valve.
Nat
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Whirpool Washer hums but does not spin (Washer Repair)
by markob 6/27/2014 7:20:54 AM(UTC)
Whirpool washer agitates but wont drain or spin (Washer Repair)
by kmsimpso 5/10/2014 9:17:09 AM(UTC)
Whirpool Washer - need help! (Washer Repair)
by jbrixey1@hotmail.com 3/31/2014 5:57:44 AM(UTC)
Whirpool washer making whirring noise (Washer Repair)
by junksasa 6/4/2013 7:18:47 AM(UTC)
whirpool washer stopped at rinse cycle and wont drian or spin (Washer Repair)
by janie527 6/1/2013 4:04:39 PM(UTC)
Whirpool washer won't drain, makes grinding noise (Washer Repair)
by coldbeerchief 1/7/2013 8:40:06 PM(UTC)
Whirpool Washer not aggitating/Spinning (Washer Repair)
by Cielo 10/24/2012 8:48:29 AM(UTC)
Whirpool washer not spinning, desperately need your help please (Washer Repair)
by dro53 9/16/2012 10:41:49 AM(UTC)
Whirpool Washer Will No Go To Rinse Cycle (Washer Repair)
by roperstopper 9/7/2012 7:07:09 AM(UTC)
Whirpool Washer - Clothes Wet After Spin (Washer Repair)
by lester100 7/17/2012 10:59:12 AM(UTC)
whirpool washer fills but wont shut off (Washer Repair)
by pete1949 6/29/2012 11:57:43 AM(UTC)
whirpool washer will agitate but will not spin (Washer Repair)
by Menard70506 6/1/2012 11:57:33 AM(UTC)
Whirpool washer Ultimate care 11 won't rinse or spin (Washer Repair)
by rckrhea2010 2/21/2012 4:41:04 PM(UTC)
Whirpool washer not working (Washer Repair)
by Chicago3110 2/1/2012 12:37:17 PM(UTC)
