Will not fill with cold water, only hot. I checked the hose for clogs and found none. What should I do next ?
I would check to see if water freely flows through the cold water spigot, then check to see if there is any obstruction of the valve inlet. If water gets to the valve, and there is little or no obstruction, then test the inlet valve for operation.
I have the same problem. Cold water runs for a little bit and then stops. Nothing in the filters and the hot is fine. Hope you have better luck........I'm going to try the one suggestion I got and replace the inlet valve. I'll let you know in about a week how it went. Hope you get more help..........
Change the water valve. Nat
