JM
JMontgomery
#1 Posted : Wednesday, October 6, 2010 1:41:06 PM(UTC)
JMontgomery
Our GE True Temp electric range bottom element in our oven does not heat up. The continuity is good in the element. The broiler element DOES work. When we turn the oven on, it seems to continuously cycle (clicking on and off) If it's the control panel, then why does everything else work?
Any suggestions?
#2 Posted : Thursday, October 7, 2010 2:36:51 AM(UTC)
[COLOR="Blue"] If it's the control panel, then why does everything else work?[/COLOR]
The control board has relays on it for the bake and broil elements. If the bake relay contacts burn out the unit will try to turn the element on but cannot.
This is probably the clicking you hear.
Could also be that a wire from the control to the element is bad.
Unplug the unit, remove the back and check them.
As usual I cannot find a wiring diagram for GE so cannot confirm the above.
Some units have an over temperature thermostat that will disconnect the bake element if tripped. I went through the parts breakdown and could not find one so am assuming your unit does not have one. If it does it is usually mounted to the back wall of the oven.
Jenn-Air JMW8527AAW display (Oven Repair (including Ranges and Cooktops))
by items 12/12/2023 1:29:40 PM(UTC)
gfe26jmmtfes ices up at all vents in ref. section (Refrigerator & Freezer Repair)
by Brysonsdad 10/30/2023 9:09:30 AM(UTC)
GE DFE29JMDEES warm freezer (Refrigerator & Freezer Repair)
by wallyh3128 5/24/2023 4:52:35 AM(UTC)
Frigidaire fsc23lr5jm1 (Refrigerator & Freezer Repair)
by Guest 10/14/2021 6:05:34 AM(UTC)
Circuit board wiring for GE model gfe24jmkffes (Refrigerator & Freezer Repair)
by Guest 6/9/2021 5:33:23 AM(UTC)
Frigidaire frs3hr5jmb2 (Refrigerator & Freezer Repair)
by Guest 4/11/2021 3:14:18 PM(UTC)
jmc8130dds turning on by itself and random beeps etc ordered parts install help. (Microwave Repair)
by tess1976 8/11/2019 11:31:31 AM(UTC)
Jenn-Air Microwave JMV8208BAS (Microwave Repair)
by MikeGMike 2/20/2019 10:53:24 AM(UTC)
jjmast (Washer Repair)
by jjmast 4/26/2013 10:14:37 AM(UTC)
jmhudgins (Dryer Repair)
by jmhudgins 1/25/2013 5:27:11 AM(UTC)
Rjm1 (Dryer Repair)
by RJM1 5/23/2012 5:53:22 PM(UTC)
jm (Washer Repair)
by jmerati@comcast.net 1/1/2011 4:21:24 AM(UTC)
Jenn-Air JMW8527DAW Locked Out (Oven Repair (including Ranges and Cooktops))
by Jim Lane 4/8/2010 1:27:51 AM(UTC)
jmy1951 (Refrigerator & Freezer Repair)
by jmy1951 12/18/2008 6:37:05 PM(UTC)
