2 Pages12>
johncirota
#1 Posted : Monday, October 4, 2010 10:47:02 AM(UTC)
johncirota
Looking for error codes for Bosch Dishwasher Model SHU43C02UC/17
#2 Posted : Monday, October 4, 2010 3:33:49 PM(UTC)
John,
What exactly is wrong with your dishwasher?
mmccarthy
#3 Posted : Tuesday, January 29, 2013 10:53:18 AM(UTC)
mmccarthy
John,
Won't run Quik Clean-up light is blinking
MM
#4 Posted : Tuesday, January 29, 2013 5:51:43 PM(UTC)
Unfortunately I could not find such error code for this model.
jenniferatkins
#5 Posted : Wednesday, January 30, 2013 4:20:17 AM(UTC)
jenniferatkins
I have not found the bosch dishwasher exact model number error code. I found this.
SHI43xx and SHU43xx Models
These series use the same initiation combo as the last set but include a different list of fault codes. A "Wash" light is a heater fault, "Rinse/Dry" is a water filling fault and "Clean" is an NTC fault.
SHU4322, SHU4326, SHU53xx, SHI68xx and SHU68xx Models
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
What error code is showing in your dishwasher? If you tell us that then in this forum have many expert. They will help you.
mmccarthy
#6 Posted : Wednesday, January 30, 2013 11:59:22 AM(UTC)
mmccarthy
after reset circuit breaker Quick Wash LED starts blinking if I hit any other key both the normal and Quick wash led's start blinking. have repeated this a few times. so do you think the control panel keypad is the problem.
MM
mmccarthy
#7 Posted : Thursday, January 31, 2013 4:21:29 AM(UTC)
mmccarthy
mmccarthy
#8 Posted : Thursday, January 31, 2013 9:32:57 AM(UTC)
mmccarthy
#9 Posted : Friday, February 1, 2013 2:33:21 PM(UTC)
It could be. I'm not able to provide more accurate advice due to lack of information.
rowingupstream
#10 Posted : Sunday, February 3, 2013 7:50:06 AM(UTC)
rowingupstream
Moved to a new thread...
2 Pages12>
