2 Pages<12
mmccarthy
#11 Posted : Monday, February 4, 2013 3:54:01 AM(UTC)
mmccarthy
It could be. I'm not able to provide more accurate advice due to lack of information.
:confused:
Model # KUDS02SRSS1 does not start. Reset circuit breaker get quick wash and normal LED's blinking then other times just get normal LED blinks.Try to use reset codes nothing happens. none of the buttons work.The last four resets of circuit breaker just got normal LED to blink.
What other info do you need?:confused:
#12 Posted : Monday, February 4, 2013 5:09:17 PM(UTC)
Originally Posted by: mmccarthy Go to Quoted Post
:confused:
Dear Sir,
Thanks God! You finally posted the model number of your dishwasher so, now I'm able to find some instructions for you.
Perform the Checking Keypad Operation procedure as instructed in the attached tech sheet and post the results.
Here are the breakdown diagrams and Parts for Whirlpool KUDS02SRSS1 Dishwasher - AppliancePartsPros.com
File Attachment(s):
Tech Sheet - 8572216 - KUDS02FRSS1.pdf (251kb) downloaded 9 time(s).
2 Pages<12
