spike27
#1 Posted : Monday, October 4, 2010 6:54:59 AM(UTC)
spike27
on a four prong plug which color wires of the four carry 120v to the dryer
#2 Posted : Monday, October 4, 2010 7:01:13 AM(UTC)
Could not find a wiring diagram but the norm is
White - Neutral
Red - 120 volts
Black - 120 volts
Green - Earth Ground (chassis)
If you are hooking up a 4 wire line cord it is important that the ground strap on the unit's terminal strip's Neutral connection to the unit's chassis be removed.
On 4 wire hook ups Neutral and Earth Ground are separate.
spike27
#3 Posted : Monday, October 4, 2010 7:31:40 AM(UTC)
spike27
thanks Denman. Im getting 120v out of the two rectangler slots on the 4-wire receptacle. when I check for voltage on the red and black wire while its not
connected to the dryer I get 120v on each wire. But, when Im connected to
the dryer i get 120V on the red wire and no voltage the black. why? Dryer
doesnt work at all not even the drum light.
#4 Posted : Monday, October 4, 2010 10:44:51 AM(UTC)
Do you get 240 between the red and black?
If not then you are reading the same side of the line.
Did this used to work or is this a new hook up?
Perhaps the following will help
http://www.applianceaid.com/electrical_testing_tips.html
