erosado
#1 Posted : Friday, October 1, 2010 7:11:49 AM(UTC)
erosado
i have a Frigidaire and my dryer is not spinning. there was a squeaking from the dryer and then it stopped squeaking and spinning too. the switch is good and there is heat being blown but the drum is not spinning. i found the diagrams but its hard to see. where is the belt and how can i get to it
sidfink43
#2 Posted : Monday, October 4, 2010 4:55:48 PM(UTC)
sidfink43
See if this service manual does not take you through the process.
http://frigidaireservicetips.com/pdfs/488_3.pdf
Frigidaire Stackable Washer Dryer Combo center (Washer Repair)
by megabyte5689 1/18/2016 2:56:21 PM(UTC)
Frigidaire stackable agitates, drains partly, no spin (Washer Repair)
by Eichelkraut 8/30/2015 9:42:41 AM(UTC)
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 9/26/2014 6:51:48 PM(UTC)
frigidaire stackable washer dryer (Washer Repair)
by youbrokeit 7/2/2014 5:10:15 AM(UTC)
Help, Frigidaire Stackable Dryer won't heat, call repairman? or easy enough to DIY? (Dryer Repair)
by latinojuan 6/13/2014 4:43:42 AM(UTC)
Frigidaire Stackable (Dryer Repair)
by SPYDAM 7/25/2011 8:32:23 AM(UTC)
Frigidaire Stackable Front Loader (Washer Repair)
by mikeandlisa1995 5/23/2010 8:06:46 AM(UTC)
Frigidaire Stackable Laundry Center Stopped Filling (Washer Repair)
by opsrn 1/16/2010 11:16:01 AM(UTC)
frigidaire stackable is leaking (Washer Repair)
by hdsnoopy75 11/12/2009 12:11:53 PM(UTC)
frigidaire stackable washer and dryer (Washer Repair)
by afeuquay001 10/18/2009 6:42:45 AM(UTC)
Frigidaire Stackable W/D, leaking tub seal (Washer Repair)
by FDAR 7/9/2009 11:48:13 AM(UTC)
Frigidaire stackable won't spin (Washer Repair)
by markpisc 5/9/2009 8:13:43 AM(UTC)
Frigidaire stackable dryer stopped heating, HELP!! (Dryer Repair)
by nmarckel26 3/17/2009 9:41:00 AM(UTC)
Used Frigidaire stackable has weird issues (Washer Repair)
by Kanine21 9/10/2008 7:00:26 AM(UTC)
