mcorneal
#1 Posted : Thursday, September 30, 2010 10:19:55 AM(UTC)
mcorneal
My Neptune has worked well for 12 years but just stopped spinning on spin cycle. The manual states that the door lock must be engaged for the spin cycle to operate. My door lock indicator does not light and the lock is apparently not engaging since I can just pull open the door. Does this indicate that the door lock is broken? Is this a replacement that can be done by a handy homeowner? Thanks!
Joe / APP Team
#2 Posted : Thursday, September 30, 2010 11:15:39 AM(UTC)
Joe / APP Team
Mc,
It may be more involved than a bad door latch assembly.
You may have a burnt R11 resistor on the control board, in the control panel,
in which case you'd need a control board and a door lock wax motor.
Part number: AP4026826
Part number: AP4026523
Yes,
If you're patient and real handy and have basic hand tools, you'll do fine.
Here's a copy of the Service Manual,
http://servicematters.co...ibrary/docs/16010061.pdf
It's not really involved at this point.
Remove the three screws across the back top of the control panel and lean the panel forward from the top and lay on a towel on the top.
The printed circuit board(machine control board) in mounted to the back panel on the right.
When you look at the left 1/3 side of the board, approximately center level, there are two horizontal resistors ( R11 and R75) if those resistors are burnt or that area of the board has any type of damage or discoloration, you can stop there and order the parts I've listed for you.
If you need more help or advice, drop us a line,
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Drains - No Spin (Washer Repair)
by Pallas63 5/20/2022 5:19:47 PM(UTC)
Electolux/Frigidaire fftw4120sw1 agitates, no spin. (Washer Repair)
by wishy_washy 11/19/2021 10:02:42 AM(UTC)
Slow to no spin maytag bravos (Washer Repair)
by Guest 7/28/2021 12:13:49 PM(UTC)
Kenmore Frontload No Spin, but does 2 second fluff spin? (Washer Repair)
by d44boy 3/4/2019 10:18:00 AM(UTC)
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
No spin after first one (Washer Repair)
by Jimbobaloue 3/15/2018 1:40:45 PM(UTC)
Whirlpool Gold Ultimate Care II Agitates but no spin (Washer Repair)
by MikeyVdub 1/8/2018 12:49:57 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Agitates and drains but no spin (Washer Repair)
by Burgerpimp 6/7/2017 10:14:27 AM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
Agitate but no Spin - Brake has lots of grease on it. (Washer Repair)
by movinglikeamovie 8/15/2016 2:27:22 PM(UTC)
Just Humming,No spin,no agitate (Washer Repair)
by buddha131 5/10/2016 3:07:32 PM(UTC)
