cwat12
#1 Posted : 16 years ago
cwat12
How do I get to the lid switch to replace it?
:confused:
Drags1998
#2 Posted : 16 years ago
Drags1998
Check My other post, I just wrote a book on how to do it on a Whirlpool washer, Thanks:)Salhasan2003 is the post you need to read.
dalu
#3 Posted : 16 years ago
dalu
I need assistance in removing top of washer so that I can replace lid switch. I have already tilted back the control panel but cannot figure out how to take top cover off.
dalu
#4 Posted : 16 years ago
dalu
Check out your other post...c'mon that's like looking for a needle in a haystack. Can't you just answer the question.
Drags1998
#5 Posted : 16 years ago
Drags1998
Sure, for YOU, anything!!!! After you have rotated the console panel back, unplug the 3 wire plug, about 1" in from the rear corners are 2 gold colored flat metal clips, insert a flat blade screw driver into the FRONT slot and pry towards the REAR of the machine, with these 2 clips removed, tilt the cabinet foward and remove from the machine.
lid switch replacement (Washer Repair)
by thosman 14 years ago
Lid switch replacement (Washer Repair)
by timberwolf 14 years ago
by quinnmiano@email.com 14 years ago
Lid Switch Replacement (Washer Repair)
by Larry G 15 years ago
older whirlpool lid switch replacement (Washer Repair)
by crmb23 15 years ago
Stackable washer lid switch replacement (Washer Repair)
by tmealy 16 years ago
Whirlpool washer lid switch replacement (Washer Repair)
by lordmandy 16 years ago
Lid Switch replacement (Washer Repair)
by aoflaherty 16 years ago
by MichelleLask 16 years ago
