cwat12
#1 Posted : Monday, October 6, 2008 3:45:19 PM(UTC)
cwat12
How do I get to the lid switch to replace it?
:confused:
Drags1998
#2 Posted : Monday, October 6, 2008 4:22:06 PM(UTC)
Drags1998
Check My other post, I just wrote a book on how to do it on a Whirlpool washer, Thanks:)Salhasan2003 is the post you need to read.
dalu
#3 Posted : Tuesday, October 21, 2008 7:02:35 AM(UTC)
dalu
I need assistance in removing top of washer so that I can replace lid switch. I have already tilted back the control panel but cannot figure out how to take top cover off.
dalu
#4 Posted : Tuesday, October 21, 2008 7:03:50 AM(UTC)
dalu
Check out your other post...c'mon that's like looking for a needle in a haystack. Can't you just answer the question.
Drags1998
#5 Posted : Tuesday, October 21, 2008 2:41:42 PM(UTC)
Drags1998
Sure, for YOU, anything!!!! After you have rotated the console panel back, unplug the 3 wire plug, about 1" in from the rear corners are 2 gold colored flat metal clips, insert a flat blade screw driver into the FRONT slot and pry towards the REAR of the machine, with these 2 clips removed, tilt the cabinet foward and remove from the machine.
Guest (4)
lid switch replacement (Washer Repair)
by thosman 5/10/2011 6:55:50 AM(UTC)
Lid switch replacement (Washer Repair)
by timberwolf 4/13/2011 9:12:28 PM(UTC)
by quinnmiano@email.com 10/12/2010 4:33:39 PM(UTC)
Lid Switch Replacement (Washer Repair)
by Larry G 8/12/2010 9:41:14 AM(UTC)
older whirlpool lid switch replacement (Washer Repair)
by crmb23 6/6/2010 6:34:17 PM(UTC)
Stackable washer lid switch replacement (Washer Repair)
by tmealy 8/18/2009 10:22:32 AM(UTC)
Whirlpool washer lid switch replacement (Washer Repair)
by lordmandy 7/27/2009 5:50:25 AM(UTC)
Lid Switch replacement (Washer Repair)
by aoflaherty 4/25/2009 1:09:18 PM(UTC)
by MichelleLask 10/29/2008 8:24:25 AM(UTC)
