I pulled the baking heating elemnt out of my oven and there was a wire attached to the right side , but no wire connected to the left side of the heating element. Did I loose the wire on the left terminal? or is it only connected on one side? (cant see any loose wires)
Yes there should be another wire it may have gotten chewed into via a mouse, you will probably need to remove the rear panel and locate the wire. Nat
