Defrost Is Not Working On This Unit, I Know How To Put It In Defrost.this Unit I See Has Main Board And Thermistors In It. How To Check The Thermistors W/out Cutting Them Out. Ice Builds Up On The Evaporator Coils. I'll See If The Heaters Work If They Do Then I'll Replace The Board.
THIS FORUM IS DEAD!!!!!!! |
