tebbettswayne@yahoo.com
#1 Posted : 15 years ago
Defrost Is Not Working On This Unit, I Know How To Put It In Defrost.this Unit I See Has Main Board And Thermistors In It. How To Check The Thermistors W/out Cutting Them Out. Ice Builds Up On The Evaporator Coils. I'll See If The Heaters Work If They Do Then I'll Replace The Board.
#2 Posted : 15 years ago
Replacement parts for GX5SHDXTQ01 models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%2012827952.pdf
The tech sheet has a thermistor test.
If you want to double check therm you could unpleg the connector at the control board and measure them there.
Whirlpool defrost problems (Refrigerator & Freezer Repair)
by bblouse 11 years ago
Refrigerator defrost problems (Refrigerator & Freezer Repair)
by Bonadu 12 years ago
More on Defrost problems post (Refrigerator & Freezer Repair)
by teppler 13 years ago
Defrost problems (Refrigerator & Freezer Repair)
by compo311 13 years ago
Defrost Problems (Refrigerator & Freezer Repair)
by RIDINHIGH 13 years ago
Repeated defrost problems (Refrigerator & Freezer Repair)
by keeneye 14 years ago
by kenwsf 15 years ago
by mr2nyse 15 years ago
GE defrost problems - question (Refrigerator & Freezer Repair)
by paulcg 15 years ago
by pahrumpcaveman 15 years ago
Frigidaire defrost problems (Refrigerator & Freezer Repair)
by rdhampton 15 years ago
by gibs 16 years ago
Refrigerator Defrost Problems (Refrigerator & Freezer Repair)
by Albert M. 17 years ago
