bucaro@rcn.com
#1 Posted : Saturday, October 4, 2008 7:34:02 AM(UTC)
bucaro@rcn.com
How do I get at the gas valve to put meter leads on it?
It is in the front of the dryer and I can't figure out how to get at it.
Joe Bucaro
SublimeMasterJW
#2 Posted : Saturday, October 4, 2008 8:43:10 AM(UTC)
SublimeMasterJW
Either 2 or 4 screws hold down the top to the front. Remove them and you can raise the top on most models. From there you can get to the screws that hold the front on. Once you get the front off you can access the gas valve assembly. Before attempting any repairs it is a good idea to clean up the dryer. Get all the lint out and clear the vents. Most of the time you are going to have a blow fuse. This keeps the gas assembly from working and setting the dryer on fire. If all the fuses are good the the flame sensor may be open if it has no continuity then that is the problem. If your sensor is good then most likely you have a bad igniter. If your igniter is ok then them operator coils are probably bad. They will half way work and quit if they are going bad. They get real hot to the touch also if they are going bad..
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
