forproctor
#1 Posted : 18 years ago
forproctor
Our ice dispenser suddenly stopped working. When you push the dispenser arm nothing happens - no motor sound and the auger does not move. The dispenser lid opens but the auger that directs ice to the opening does not move. The water dispenser works as does the light in the dispenser opening in the door.
Is this problem due to motor failure or is it a relay switch? We live in Phoenix and have heavy calcium levels in our water. Even though we replace the water filter regularly, we are showing some calcium build-up on the dispenser arm for the water dispenser.
Your customer service rep says that he sells quite a few motors for the dispenser for this refrigerator model but wanted me to make sure that the calcuim level might not be the problem in this case.
Please advise!
Matt / APP Team
#2 Posted : 18 years ago
Matt / APP Team
Rank: Administration
Groups: Administrators
You will have to determine if the motor is getting power or not! Should be pretty basic, you will just hae to use your testing meter to determine it. If the motor is getting power then it is probably bad.
Click for motor.
If it is not getting power you will have to check the wiring and the dispenser switch.
Click for dispenser switch.
Check those out and see what you can determine. As far as the calcium goes it shouldnt affect it the motor and switch do not come in contact with the water or ice.
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave about a year ago
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern about a year ago
Door Ice dispenser not functioning properly (Refrigerator & Freezer Repair)
by abennet4@comcast.net about a year ago
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 2 years ago
Ice dispenser light on Frigidaire FGHC2342LF3 not working (Refrigerator & Freezer Repair)
by parkerfly 2 years ago
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 2 years ago
how to determine if kenmore ice dispenser is bad (Oven Repair (including Ranges and Cooktops))
Frigidaire water/ice dispenser issue FFHS2322MSKA (Refrigerator & Freezer Repair)
Ice dispenser freezing (Refrigerator & Freezer Repair)
by jesus freak 2 years ago
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 2 years ago
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 2 years ago
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 3 years ago
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 3 years ago
Frigidaire FRS6LF8FS1 ice dispenser not dispensing ice (Refrigerator & Freezer Repair)
by BradASchreiber 3 years ago
Water/ice dispenser funnel won’t retract (Refrigerator & Freezer Repair)
