I changed the fuse and thermast. What else should I do?
Why did you change the fuse and thermostat? do you have tools to test continuity? Its possible you have incorrect power supply to the dryer or the heater element is open, without a multi meter you won't be able to test your voltage, you can visibly inspect the element though,its just a long coil, like a toaster, if its broken, its bad.
