The dishwasher leaks when water is being pumped out of the washer - after the first rinse, then after the wash, then after the final rinse. The rest of the time, while washing, no leaks. total leak amount is about 1 cup per load. What shoudl I replace?
Here are your parts Replacement parts for General Electric GSD1130R45WA Dishwasher | AppliancePartsPros.com[COLOR="Blue"]What shoudl I replace?[/COLOR] Only you can tell as there are a number of items in the drain path. Remove the kick plate and find the leak. May be as simple as replacing a clamp. A small mirror and a flashlight come in handy when trying to track down leaks. A mirror like the ones mechanics use, which is on a handle is ideal. Yo could also tape a small mirror to a piece of doweling etc. |
THIS FORUM IS DEAD!!!!!!! |
