Greetings, Need advice on checking pump or removing from bottom of dishwasher so I can check to see if any blockage. I've dissassembled down to the pump volute but can't get it removed because of the horizontal shaft that protrudes through the side. I've blown air down from the top vent and hear and see bubbles inside the dishwasher, no blockage that i can tell, motor does swirl the water around on the 1 minute rinse cycle but does not drain. Ihave taken the 3 torx head screws loose on the top of the pump housing but i assume i need to pull the horitzontal shaft somehow? Thanks for you help!:confused:
