scott3151
#1 Posted : Tuesday, September 23, 2008 5:53:16 PM(UTC)
scott3151
Greetings, Need advice on checking pump or removing from bottom of dishwasher so I can check to see if any blockage. I've dissassembled down to the pump volute but can't get it removed because of the horizontal shaft that protrudes through the side. I've blown air down from the top vent and hear and see bubbles inside the dishwasher, no blockage that i can tell, motor does swirl the water around on the 1 minute rinse cycle but does not drain. Ihave taken the 3 torx head screws loose on the top of the pump housing but i assume i need to pull the horitzontal shaft somehow? Thanks for you help!:confused:
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
