I have a gas GE range and the front left burner stopped working all of a sudden. When I turn the burner on, I hear it clicking but does not ignite. I can use matches to turn it on. Is it the ignitor? Rest of the burners seem to work just fine. Let me know if its easy to fix.
Thanks!
Can you post the rest of your model number? It should be on your stove, either under the top panel or on the frame when you open the storage drawer. Nat
It's an easy fix, replace the spark switch for that burner and you should be good to go. Here's the breakdown Model JGBP35BEA9BB. Nat
