luke75
#1 Posted : Monday, September 22, 2008 6:46:15 PM(UTC)
luke75
I have a gas GE range and the front left burner stopped working all of a sudden. When I turn the burner on, I hear it clicking but does not ignite. I can use matches to turn it on. Is it the ignitor? Rest of the burners seem to work just fine. Let me know if its easy to fix.
Thanks!
libertyappl
#2 Posted : Monday, September 22, 2008 6:49:27 PM(UTC)
libertyappl
Can you post the rest of your model number? It should be on your stove, either under the top panel or on the frame when you open the storage drawer.
Nat
luke75
#3 Posted : Monday, September 22, 2008 6:58:43 PM(UTC)
luke75
Jgbp35bea9bb
libertyappl
#4 Posted : Monday, September 22, 2008 7:03:05 PM(UTC)
libertyappl
It's an easy fix, replace the spark switch for that burner and you should be good to go.
Here's the breakdown Model JGBP35BEA9BB.
Nat
samsung electric burner not working (Oven Repair (including Ranges and Cooktops))
by ag0240 8/21/2022 1:58:31 PM(UTC)
Frigidaire range burner not working (Oven Repair (including Ranges and Cooktops))
by Hatt65 12/6/2020 11:35:18 AM(UTC)
Thermador x-lo burner not working (Oven Repair (including Ranges and Cooktops))
by burright 12/30/2014 4:45:01 PM(UTC)
Inner ring of 3 ring burner not working. (Oven Repair (including Ranges and Cooktops))
by William Johnson 3/17/2014 3:58:56 PM(UTC)
Kenmore gas range bottom burner not working (Oven Repair (including Ranges and Cooktops))
by scott mcgourley 10/29/2013 9:09:28 AM(UTC)
Left Front burner not working (Oven Repair (including Ranges and Cooktops))
by tyee3 2/18/2013 2:19:47 PM(UTC)
GE Spectra Profile - Large Burner not working properly - even after replacement (Oven Repair (including Ranges and Cooktops))
by friarpat 12/14/2012 9:15:17 PM(UTC)
Burner ON light stays lit but burner not working (Oven Repair (including Ranges and Cooktops))
by mkc5869 4/19/2012 6:03:56 AM(UTC)
top right burner not working (Oven Repair (including Ranges and Cooktops))
by erakowsky 4/9/2012 5:28:22 AM(UTC)
Range top burner not working (Oven Repair (including Ranges and Cooktops))
by Rolands 3/29/2012 7:25:32 PM(UTC)
Kitchenaid RR burner not working (Oven Repair (including Ranges and Cooktops))
by curtball 3/16/2012 8:32:38 AM(UTC)
Kenmore elite burner not working (Oven Repair (including Ranges and Cooktops))
by Keaka 2/27/2012 2:46:20 PM(UTC)
Jenn Air Burner Not Working (Oven Repair (including Ranges and Cooktops))
by whiterr 11/18/2011 5:24:59 AM(UTC)
glass top burner not working on whirlpool range (Oven Repair (including Ranges and Cooktops))
by heidishandy 10/22/2011 7:54:41 AM(UTC)
Burner not working (Oven Repair (including Ranges and Cooktops))
by Tiny 9/22/2011 8:27:31 AM(UTC)
