BARDOME'
#1 Posted : Monday, September 6, 2010 11:36:27 AM(UTC)
BARDOME'
What is the correct procedure to remove the agitator?
eraserskin
#2 Posted : Monday, September 6, 2010 12:32:06 PM(UTC)
eraserskin
Usually if can get your fingers under it and pull up it should pop off. If you can't get your fingers under it then try using a belt or a strap to slide under and around the agitator and pull up with that. That has always worked for me. Good luck.
GE Stacked washer dryer - Agitator Removal (Dryer Repair)
by Guest 5/31/2021 10:26:51 AM(UTC)
Kenmore 20022011 agitator removal (Washer Repair)
by d0ugparker 3/18/2015 8:46:07 AM(UTC)
kenmore agitator removal - bolt turns but won't come out (Washer Repair)
by kimkim 3/2/2015 9:25:47 AM(UTC)
Amana agitator removal (Washer Repair)
by Max Strasser 8/6/2014 11:09:33 AM(UTC)
Agitator Removal (Washer Repair)
by fourspots 5/3/2013 8:51:25 AM(UTC)
Older Maytag Washer Agitator Removal (Washer Repair)
by rjhornak 4/20/2012 10:40:17 AM(UTC)
Agitator removal (Washer Repair)
by kenziegranny 2/12/2012 7:36:24 AM(UTC)
by cutthroattrout1 1/4/2012 1:26:48 AM(UTC)
agitator removal steps; is washer lid removal required (Washer Repair)
by tomdrzich@hotmail.com 8/11/2011 5:36:48 AM(UTC)
by sabado 1/14/2011 6:22:25 PM(UTC)
by rpflynnsr 12/21/2010 11:13:40 AM(UTC)
by engcash 10/20/2010 11:01:54 AM(UTC)
Hotpoint agitator removal (Washer Repair)
by dleatherbu 10/10/2010 10:40:20 AM(UTC)
1980s whirlpool agitator removal (Washer Repair)
by billhuber 10/4/2010 5:20:06 PM(UTC)
agitator removal help (Washer Repair)
by anomaly 6/14/2010 12:07:44 PM(UTC)
