drowe
#1 Posted : Thursday, September 18, 2008 2:58:01 PM(UTC)
drowe
I recently purchased a used KENMORE PORTABLE WASHER AND DRYER AND I ORDERED AN APAPTER (AP2907963) and hose (AP2913339) from your company.
I was able to put the adapter on the faucet but an unable to get the hose to attached firmly to the adapter, when I turn on the water the hose falls off and I am unable to fill the washing machine.
Please help me to get this to work!!!!!
Thank you
libertyappl
#2 Posted : Thursday, September 18, 2008 6:51:39 PM(UTC)
libertyappl
With both new parts about the only suggestion is to make sure you are hooking the hose to the adapter evenly, if it's "cocked" a little it will pop right off. I'm sure you know to pull the outside part on the hose down while attaching then push up a little. Try pulling gently on the discharge hose after you atttach it to make sure it's secured good.
The reason I say that is several years ago my aunt let me use her portable washer while I was having a washer & dryer hookup to be installed in a house I bought without a utility room. Had never seen or used one, got a wet face more than once :P
Nat
Kenmore portable washer leaks (Washer Repair)
by Jimisand 3/9/2015 10:38:25 AM(UTC)
water level control kaput? Kenmore portable washer (Washer Repair)
by damenefee 10/25/2011 10:18:54 AM(UTC)
Portable Washer attachmnet to the faucet (Washer Repair)
by AlexN 3/28/2011 3:19:28 PM(UTC)
Kenmore Portable Washer (Washer Repair)
by letsgoalltheway 3/29/2009 8:25:16 AM(UTC)
my portable washer is gushing water out of the bottom... (Washer Repair)
by Washerblues 4/8/2008 5:47:10 PM(UTC)
