Washerblues
#1 Posted : Tuesday, April 8, 2008 5:47:10 PM(UTC)
Washerblues
When my Kenmore portable washer, model 110.49722990 is draining and and starts spinning, water gushes out of the bottom. However, when I have it drain only or spin only, it does not leak.
Any suggestions?
UserPostedImage
#2 Posted : Wednesday, April 9, 2008 2:43:17 PM(UTC)
This is something very strange. Remove the top panel and the rear access panel and try to pinpoint the water leak.
Washerblues
#3 Posted : Monday, April 14, 2008 8:35:28 AM(UTC)
Washerblues
So I looked at taking the panels off, but there were a lot of pieces that appear to be fixed, so I started looking at the attachments first.
What I found was a bobby pin had gotten stuck in the return hose and had caused a partial clog so all the water could not get out and was pushing out the other end of the hose only when draining and spinning.
I have removed the clog and everything is good far! I hope it was as easy at that!
Thanks Gene, for taking the time to respond to my problem!
Cheers!
#4 Posted : Tuesday, April 15, 2008 8:46:03 PM(UTC)
I'm glad you were able to fix it.
