AppliancePartsPros.com
Appliance Repair Help
Washer Repair
my portable washer is gushing water out of the bottom...
When my Kenmore portable washer, model 110.49722990 is draining and and starts spinning, water gushes out of the bottom. However, when I have it drain only or spin only, it does not leak.
Any suggestions?
This is something very strange. Remove the top panel and the rear access panel and try to pinpoint the water leak.
So I looked at taking the panels off, but there were a lot of pieces that appear to be fixed, so I started looking at the attachments first.
What I found was a bobby pin had gotten stuck in the return hose and had caused a partial clog so all the water could not get out and was pushing out the other end of the hose only when draining and spinning.
I have removed the clog and everything is good far! I hope it was as easy at that!
Thanks Gene, for taking the time to respond to my problem!
Cheers!
I'm glad you were able to fix it.
Washer Repair
