HELP:mad: I have an older portable washer that is over 10yrs old and the problem is everything works fine but when it comes to the draining the washer will not drain . I have tried every cycle and its the same on every cycle. Normally after the wash cycle you can hear a little click sound from the switch before it switches to drain but you dont hear that little click sound.would that be the switch is gone or is it possible that the drain hole in the washer is plugged would this cause it not to kick in and drain;)
it does go through the cycle but dont spin or drain
