Johanna
#1 Posted : Monday, September 15, 2008 3:41:12 AM(UTC)
Johanna
I have a Kenmore 18 cu ft refrigerator that I would guess is around 5 years old. I notice water on the floor in front of and underneath the refrigerator. I traced the water source to the inside of the refrigerator. I thought it might have been the humidity this summer but I am sure we've had humid days and humid summers in the past five years, We have to use a sponge to soak up the water every so often and even used stormbag to that problem Stormbag - Alternative Sandbag can someone help us to fix that problem
Johanna
libertyappl
#2 Posted : Monday, September 15, 2008 8:05:05 AM(UTC)
libertyappl
Johanna,
That problem is usually caused by a frozen or clogged defrost drain. Locate the drain in the back of the freezer compartment to check which it is. If it's frozen you can use hot water with a turkey baster or tube to thaw it out.
Please post your model number if you need further assistance.
Nat
Johanna
#3 Posted : Monday, September 15, 2008 9:47:51 PM(UTC)
Johanna
Thanks for the reply, I will try your advice
libertyappl
#4 Posted : Tuesday, September 16, 2008 6:53:01 AM(UTC)
libertyappl
Let us know if you need anythng else.
Nat
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
