wanni01
#1 Posted : Tuesday, August 31, 2010 9:52:45 AM(UTC)
wanni01
Using the achives from your repair forum, I have narrowed down the problem (no cooling in the refrigerator but freezer works) to the defrost thermostat.
If I install the new thermostat, I was wondering if I can actually see the heater working before I put everything back together. Can I set the timer so that the defrost heater will come on without having to wait? What does 10hr/35min defrost timer mean? Does it mean the defrost heater will come on for 35min for every 10hrs the compressor operates?
Thanks very much,
Nick
#2 Posted : Tuesday, August 31, 2010 10:19:51 AM(UTC)
[COLOR="Blue"]Can I set the timer so that the defrost heater will come on without having to wait?[/COLOR]
Yes just rotate the cam with a screw driver.
There is usually a hole in the unit cover to do this.
Note, that it only turns in one direction.
When the fans and compressor go off you are in a defrost cycle and the heater should heat up.
Be careful that you do not burn your fingers.
[COLOR="Blue"]
What does 10hr/35min defrost timer mean? Does it mean the defrost heater will come on for 35min for every 10hrs the compressor operates?[/COLOR]
Yes it can.
On some units it is wired directly across power in so then you get a 35 minute defrost cycle every 10 hours.
wanni01
#3 Posted : Tuesday, August 31, 2010 10:58:50 AM(UTC)
wanni01
Thank you.
After I rotate the cam to test the heater, how much do I need to turn (180 degrees?) to move it back to the original setting?
The heater will only come on if the thermostat is functioning (closed - when cold), correct?
Thanks again,
Nick
#4 Posted : Tuesday, August 31, 2010 11:35:07 AM(UTC)
[COLOR="Blue"]After I rotate the cam to test the heater, how much do I need to turn (180 degrees?) to move it back to the original setting?[/COLOR]
Just till the fans and compressor come back on, around 20 degrees.
Yes, the thermostat must be frozen.
wanni01
#5 Posted : Tuesday, August 31, 2010 11:51:52 AM(UTC)
wanni01
What is the best way to ensure that the thermostat is frozen so that I can test the heater?
I have been assuming that my heater is okay because there is continuity across the terminals. However, the resistence is only 22 ohms. Does that sound right to you?
#6 Posted : Wednesday, September 1, 2010 12:44:19 AM(UTC)
[COLOR="Blue"]What is the best way to ensure that the thermostat is frozen so that I can test the heater?[/COLOR]
You could just place the metal face of it on an ice cube, often you will hear it click closed.
[COLOR="Blue"]
However, the resistence is only 22 ohms. Does that sound right to you?[/COLOR]
Yes the heater looks OK
wanni01
#7 Posted : Wednesday, September 1, 2010 3:50:12 AM(UTC)
wanni01
I replaced the defrost thermostat and the timer, purchased from you, (I think the old timer still works but it is inexpensive insurance) last night. I then tested the heater per your advice and the heater worked. You are right, it got red hot and burned the mitten I used under it. I put everything back together and the refrigerator was 36C this morning.
Thank you very much. You guys are great and I really apprciate it.
Nick
#8 Posted : Wednesday, September 1, 2010 7:10:24 AM(UTC)
Glad to hear you got it fixed.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
