Blackhawk37
#1 Posted : Monday, August 30, 2010 3:41:30 PM(UTC)
Blackhawk37
How are the motor and the plastic impeller separated? The motor is mounted to the inside floor of the dryer, and the impeller is attached to a shaft through the case to the back of the machine.
#2 Posted : Tuesday, August 31, 2010 1:44:20 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Frigidaire FSG747GES0 dryer motor (P/N 131461900) growls on start (Dryer Repair)
by RJ539 1/12/2024 9:00:21 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Dryer motor wiring (Dryer Repair)
by jebradl 9/5/2023 12:12:52 PM(UTC)
Dryer Motor - Oil or Replace? (Dryer Repair)
by Pete Pliers 10/25/2022 10:08:07 AM(UTC)
wgd5300sq0 new dryer motor and blower wheel. But blower wheel keeps falling off (Dryer Repair)
by Ebnuno 2/6/2022 7:55:20 AM(UTC)
Dryer Motor Voltage. (Dryer Repair)
by Tubalard 1/6/2021 2:48:44 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
GE Dryer motor tries to start, but is only successful every 20th time or so (Dryer Repair)
by jpswensen 4/20/2020 10:12:33 AM(UTC)
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 9/19/2019 11:59:22 AM(UTC)
Dryer Motor Replacement - wiring (Dryer Repair)
by houkden1 1/9/2018 5:12:44 PM(UTC)
Dryer Motor clamp / clip installation technique ? (Dryer Repair)
by diydude99 12/9/2017 12:07:41 PM(UTC)
Dryer motor alignment? (Dryer Repair)
by gvbill 8/9/2017 8:57:03 AM(UTC)
Dryer Motor Not Running Click heard (Dryer Repair)
by FixHR 12/23/2016 7:19:17 AM(UTC)
