i have an in the door ice maker/water dispenser that has quit dispencing water. It dispences ice fine,and i have changed the water filter,and checked line for kinks. it is a second home,not used but 2/3 days a month bu us...any suggestions?
Do you hear a clicking when you press the lever for water? If not the switch or lever may be broken in the dispenser. Can you post your model number? Nat
Originally Posted by: libertyappl ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Do you hear a clicking when you press the lever for water? If not the switch or lever may be broken in the dispenser. Can you post your model number? Nat no,no noise when pushing lever...i am not at the house now,model unknowm..but only 3 years old,and it has worked up until 6 mo's ago..
It's probably not going to take a lot to fix. when you get back to that house post your model number. Nat
