Ice Maker started overflowing with water. Replaced Optical Sensors, Replaced Water Filter, Replaced Complete Ice Maker Assembly/Tray/Motor. Water flows strong into water dispenser. Water Inlet Valves read between 250 to 450 Ohms. Is there a relay or other that i can check?
