sbww13
#1 Posted : Saturday, November 29, 2014 10:51:07 AM(UTC)
sbww13
Whirlpool side by side Gold series
Freezer is not freezing, not getting cold enough. the condenser is not clicking it is vibrating and running. the fan on outside underneath is running, the fan inside in freezer section is running, there is no build of frost. it was unplugged and completely defrosted. i re-plugged it in starting to diagnose it took back panel off in freezer, the fan runs, but the coils inside get frost on them only about two rows from bottom. the rest show no signs of frosting. i know a little, but not enough to figure it out thank you for any help.
#2 Posted : Saturday, November 29, 2014 12:21:34 PM(UTC)
Sounds like a sealed system problem.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
See the three example pictures about half way down the page in the below link.
http://www.applianceaid.com/ref...ator-not-cold-enough.php
