stlcpd3765
#1 Posted : Tuesday, August 24, 2010 8:45:03 PM(UTC)
stlcpd3765
My washing machine just recently started making this loud thumping noise at the end of the spin cycle. I am thinking that it is the clutch or brake parts. This is gear driven, not belt. Everything else is working and the clothes are getting cleaned. Any ideas?
#2 Posted : Wednesday, August 25, 2010 7:16:17 AM(UTC)
I would pull the agitator and check the drive block nut, if loose, you probably wore the spin tube tabs.
