AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer makes thumping noise at end of spin cycle
My washing machine just recently started making this loud thumping noise at the end of the spin cycle. I am thinking that it is the clutch or brake parts. This is gear driven, not belt. Everything else is working and the clothes are getting cleaned. Any ideas?
I would pull the agitator and check the drive block nut, if loose, you probably wore the spin tube tabs.
Washer Repair
