chrisn1
#1 Posted : Friday, August 20, 2010 3:00:50 AM(UTC)
chrisn1
I have a GE side by side fridge freezer about 10 to 12 years old that has developed a serious leak on the freezer side. There appears to be a drain hole at the back but water has been accumulating at the bottom freezing and then running out the door onto the floor. Is this something I can fix or is it time to call the repair guy?I cannot see where the water is coming from, thought maybe because of the very high humidity it was just defrosting itself excessively.
kayakcrzy
#2 Posted : Friday, August 20, 2010 3:43:33 AM(UTC)
kayakcrzy
That water comes down in the freezer, when the refrigerator goes in defrost. So the water is normal. The drain hole is frozen over. That is why the water is going on the floor, and I am sure there is a block of ice in the bottom of the freezer. Take the bottom draw out, and knock the ice out. Then knock the ice out away from the whole and get a blow dryer, and hold it over the whole. After a little bit, get a boiling hot cup of water, and pour some down the hole, and let it sit, and see if it drains. If so, your done. If not, wipe the water up, and get the blow dryer on the whole, after a little bit, pour some more of that hot water in the hole, and give it a minute, to defrost some of the ice, and then wipe it up, and repeat the process untill the water drains down the hole. You don't need no service man. Follow these directions, and you will get it. Let me know how it goes. Tom ApplianceEducator.com
chrisn1
#3 Posted : Friday, August 20, 2010 2:22:48 PM(UTC)
chrisn1
Thanks,I thought that was it but never thought of the drain hole being clogged.All is well now, thanks again
kayakcrzy
#4 Posted : Saturday, August 21, 2010 6:00:10 AM(UTC)
kayakcrzy
Good job!! Glad to help. Tom ApplianceEducator.com
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
