Dear All-knowing Ones, The clock/timer/temperature LCD display won't work, but the cooktop and the over light are fine. Please tell me what is the problem and what part I need to order. Thanks. Georgene Wade
You will need to check and see if you have power to the clock. If you do then the clock will need to be replaced.
