Alex2000
#1 Posted : Thursday, August 28, 2008 9:21:00 PM(UTC)
Alex2000
The condenser fan motor was not working but the compressor works. We do not have 115v at the Fan motor.. I am running the Condenser fan motor directly to the outlet the Refrigerator works fine. I have replaced the PCB control p/n 2307028 after I have replaced the pcb everything works but not the compressor neither the condenser fan motor. Then I have put the old one back.. it did the samething I left the old in the unit. now unit works but still I have conected the fan motor directly to 115v. My question is maybe the PCB has some delay time because the refrigerator it is cold. how long it will take to start the comressor and the fan motot.. oh by the way the new PCB has not the big coild that has the old but all the connector are fine maybe this is just was upgraded.
Ohh should I punch any code on the keypad . I have not seen any code #
libertyappl
#2 Posted : Friday, August 29, 2008 12:45:59 PM(UTC)
libertyappl
By looking at your model the control board #2307028 (this is for the 03 not the 00) is not the right board for your model. It be 2307037 and you might want to check the wire harness to find if you have a broken or chewed wire for the fan.
nat
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
