The condenser fan motor was not working but the compressor works. We do not have 115v at the Fan motor.. I am running the Condenser fan motor directly to the outlet the Refrigerator works fine. I have replaced the PCB control p/n 2307028 after I have replaced the pcb everything works but not the compressor neither the condenser fan motor. Then I have put the old one back.. it did the samething I left the old in the unit. now unit works but still I have conected the fan motor directly to 115v. My question is maybe the PCB has some delay time because the refrigerator it is cold. how long it will take to start the comressor and the fan motot.. oh by the way the new PCB has not the big coild that has the old but all the connector are fine maybe this is just was upgraded. Ohh should I punch any code on the keypad . I have not seen any code #
By looking at your model the control board #2307028 (this is for the 03 not the 00) is not the right board for your model. It be 2307037 and you might want to check the wire harness to find if you have a broken or chewed wire for the fan. nat
