PAULB39
#1 Posted : Sunday, August 15, 2010 7:28:40 AM(UTC)
PAULB39
My freezer working fine, fridge is not cold. took off back in freezer and it seems the fan isnt blowing any air into the fridge. would it be just the fan to replace or could it be something else?
PAULB39
#2 Posted : Sunday, August 15, 2010 7:32:16 AM(UTC)
PAULB39
freezer working fridge isn't cold. if the fan isn't running do I need a new fan or could it be another problem?
#3 Posted : Sunday, August 15, 2010 7:40:56 AM(UTC)
Here is your wiring diagram.
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202225759.pdf
As you can see the evaporator fan and compressor and condenser fan are all in parallel so if the other 2 work then odds are high that the evaporator fan is shot.
This can be checked by measuring the voltage across the fan.
Also check that you do not have a defrost problem that is so bad it is jamming the fan.
PAULB39
#4 Posted : Sunday, August 15, 2010 7:50:53 AM(UTC)
PAULB39
Thanks! Does fan normaly run at all times or does go on and off? Also is it easy to replace?
#5 Posted : Sunday, August 15, 2010 8:12:49 AM(UTC)
[COLOR="Blue"]Does fan normaly run at all times or does go on and off?[/COLOR]
Only runs when the compressor runs.
[COLOR="Blue"]Also is it easy to replace?[/COLOR]
Usually they are not hard to replace.
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
LG french door refrigerator ice maker fan not working (Refrigerator & Freezer Repair)
by md5757 11/6/2023 11:27:11 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Hood lights and fan not working (Microwave Repair)
by charlienoble 11/13/2021 10:30:09 AM(UTC)
U-Line Evaporator Fan Not working (Refrigerator & Freezer Repair)
by roscoej 10/5/2021 7:24:11 PM(UTC)
FIXED: Evap fan not working, running out of fixes! (Refrigerator & Freezer Repair)
by DEMinSoCAL 7/18/2021 7:06:44 AM(UTC)
Condenser Fan Not Working (Refrigerator & Freezer Repair)
by ToneB 7/17/2016 8:30:50 PM(UTC)
evaporator fan not working, help!! (Refrigerator & Freezer Repair)
by MLF4 1/30/2016 3:33:38 PM(UTC)
evaporator fan not working (Refrigerator & Freezer Repair)
by rnjackson1 10/9/2015 1:04:39 PM(UTC)
Evaporator Fan Not Working (Refrigerator & Freezer Repair)
by dwgfelix 9/8/2015 8:36:01 AM(UTC)
Whirlpool microwave vent fan not working (Microwave Repair)
by mshaw8099 7/22/2015 2:07:41 PM(UTC)
Compressor fan not working (Heating, Ventilation, and Air Conditioning (HVAC))
by dansally 8/24/2014 6:21:25 AM(UTC)
Vent fan not working (Microwave Repair)
by JimLk 5/14/2014 2:05:57 PM(UTC)
Jenn Air Convection Fan Not Working (Oven Repair (including Ranges and Cooktops))
by johncher 3/14/2014 10:26:03 AM(UTC)
GE profile fridge fan not working (Refrigerator & Freezer Repair)
by KevinM52 10/28/2013 4:12:19 PM(UTC)
