castillocm
#1 Posted : Friday, August 13, 2010 7:29:26 PM(UTC)
castillocm
Hello,
I have problems with my washing machine, I started the machine, I put the clothes, closed the door and then put the detergent, it filled with water, it did the cycles, it did the spins, but the water didn't come out, finally the door was open and I saw the clothes wet with soap.
Two years ago the machine had the Wax motor replaced, I got the Complete R-11 Q6 Repair kit.
Please help me ASAP, the clothes are still wet with soap.:(
Thank you,
Cielo
castillocm
#2 Posted : Friday, August 13, 2010 7:36:36 PM(UTC)
castillocm
Hello,
Thank you,
Cielo
Reset washer machine (Washer Repair)
by Guest 3/16/2021 1:30:34 PM(UTC)
A GE washer machine cycles up until it need to spin and drAin .. just sits there (Washer Repair)
by Toomas72 3/5/2021 2:54:16 PM(UTC)
Kenmore washer machine , failing (Appliance Repair Companies - East of the Mississip)
by Glasstooler 1/3/2019 4:55:02 PM(UTC)
Washer Machine (Washer Repair)
by Phoohbaby1 11/20/2014 7:55:08 PM(UTC)
Admiral Washer Machine Water Temp Not Working Correctly (Washer Repair)
by CRAIG1978 7/26/2014 11:08:17 AM(UTC)
Noisey washer machine (Washer Repair)
by Pavlo 3/28/2012 7:36:42 PM(UTC)
by Allen12 1/17/2012 12:48:48 PM(UTC)
Maytag Neptune Washer Machine (Washer Repair)
by margioesc1973 10/9/2011 10:13:34 AM(UTC)
Whirlpool washer machine problem (Washer Repair)
by matogi7 9/23/2011 3:43:26 PM(UTC)
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? (Washer Repair)
by maddy 6/15/2011 9:11:07 AM(UTC)
Washer Machine timer won't turn off. (Washer Repair)
by garystarh 5/27/2011 7:25:24 AM(UTC)
Admiral washer machine (Washer Repair)
by 01queenie01 5/8/2011 9:14:49 AM(UTC)
My washer machine does not start (Washer Repair)
by Traci Thornton 4/17/2011 4:58:33 PM(UTC)
Washer machine will not fill with water (Dishwasher Repair)
by paisaac 3/29/2011 9:40:32 AM(UTC)
washer machine won't spin (Washer Repair)
by elbebe2525 1/6/2010 10:59:58 AM(UTC)
