Dannyk
#1 Posted : Friday, August 13, 2010 4:51:54 AM(UTC)
Dannyk
My wife called a repairman he said that the dishwasher needed a mtr, the mtr works, is there a way I can test the motor it doesn’t seem to be failing.
Joe / APP Team
#2 Posted : Friday, August 13, 2010 6:15:39 AM(UTC)
Joe / APP Team
If you have a multimeter,
Disconnect the motor harness, and do the following tests on the motor :
White to Yellow 6.5 ohms (wash winding).
White to Gray 6.5 ohms (drain winding).
White to blue/wht 1.8 ohms (start winding).
Give yourself 10% high or low and your motor will check to factory specifications.
What is your actual complaint ?
:cool: :cool:
