eevans1137
#1 Posted : Tuesday, August 26, 2008 9:14:45 AM(UTC)
eevans1137
My Freezer Wont Defrost Every Thing On Frigerator Side Not Cold Have To Defrost Freezer Side Then Works Fine For Few Days Then Do It Again I Ordered Thermostat Kit Can Any Body Tell Me If It Will Fix Problem Or What Will?
libertyappl
#2 Posted : Tuesday, August 26, 2008 9:37:36 AM(UTC)
libertyappl
I don't think that's going to help you. Remove the rear panel in the freezer side and see if it's all iced up. If so remove the control panel in the frig side and locate the defrost timer advance the timer unit intil the unit shuts off and listen for ice popping in the freezer side. If it doesn't shut off with a complete turn then that's your problem or at least part of the problem, order the timer and use a hair dryer to melt all the ice, which should keep you cooling until you new part gets in.
Post your results.
Nat.
Automatic Defroster Not Working (Refrigerator & Freezer Repair)
by Shawdan3 7/20/2015 2:46:41 PM(UTC)
maytag refrigerator defroster not working (Refrigerator & Freezer Repair)
by gse 2/28/2010 11:22:02 AM(UTC)
Defroster not working on Samsung Fridge...please help (Refrigerator & Freezer Repair)
by ChaoticBliss 9/23/2009 3:27:44 PM(UTC)
GE defroster not working (Refrigerator & Freezer Repair)
by jerryblewis 9/25/2008 10:17:48 AM(UTC)
Defroster not working.Freezie Pops not frozen (Refrigerator & Freezer Repair)
by brew 8/26/2008 7:26:44 AM(UTC)
Defroster not working (Refrigerator & Freezer Repair)
by biggxj 10/9/2007 9:12:50 AM(UTC)
