My Freezer Wont Defrost Every Thing On Frigerator Side Not Cold Have To Defrost Freezer Side Then Works Fine For Few Days Then Do It Again I Ordered Thermostat Kit Can Any Body Tell Me If It Will Fix Problem Or What Will?
I don't think that's going to help you. Remove the rear panel in the freezer side and see if it's all iced up. If so remove the control panel in the frig side and locate the defrost timer advance the timer unit intil the unit shuts off and listen for ice popping in the freezer side. If it doesn't shut off with a complete turn then that's your problem or at least part of the problem, order the timer and use a hair dryer to melt all the ice, which should keep you cooling until you new part gets in. Post your results. Nat.
