mfairbanks
#1 Posted : Sunday, August 24, 2008 6:58:47 PM(UTC)
mfairbanks
I am not sure if I have the correct model # since it is worn off some. This is what I think it is D110096GQ1. The serial # is FV2804163. When it starts up there is a buzzing noise after awhile it seems to go away. But this time it did not fully drain. I had to push the cancel/drain button 3 times and it finally worked.
Is my motor going bad or do I need to clean something out?
libertyappl
#2 Posted : Sunday, August 24, 2008 7:02:08 PM(UTC)
libertyappl
The model number posted does not pull up. But you may just have something in your pump.
Look at your model number again it should start with a DU
Nat
mfairbanks
#3 Posted : Wednesday, August 27, 2008 2:37:44 PM(UTC)
mfairbanks
I had to call Whirlpool and think I have the model # it is DU1000CGQ1. It has been washing fine but does not drain, what could it be and how can I fix it?:confused:
libertyappl
#4 Posted : Wednesday, August 27, 2008 5:32:22 PM(UTC)
libertyappl
Could be something stuck in the pump or the pump is out. Check for an obstruction.
mfairbanks
#5 Posted : Thursday, August 28, 2008 4:32:40 AM(UTC)
mfairbanks
Do I take it apart from the inside?
Inside the garbage disposal where the drain is, I stuck my finger to see what would happen if I plugged it a little bit. It seems to have good pressure when I do that. So there must be something stuck in the hose, Just a guess?
mfairbanks
#6 Posted : Tuesday, September 2, 2008 10:59:17 AM(UTC)
mfairbanks
I found that the check valve had some stuff caught on the end of it and inside. Problem fixed!!:D
