I am not sure if I have the correct model # since it is worn off some. This is what I think it is D110096GQ1. The serial # is FV2804163. When it starts up there is a buzzing noise after awhile it seems to go away. But this time it did not fully drain. I had to push the cancel/drain button 3 times and it finally worked.
Is my motor going bad or do I need to clean something out?
The model number posted does not pull up. But you may just have something in your pump. Look at your model number again it should start with a DU Nat
I had to call Whirlpool and think I have the model # it is DU1000CGQ1. It has been washing fine but does not drain, what could it be and how can I fix it?:confused:
Could be something stuck in the pump or the pump is out. Check for an obstruction.
Do I take it apart from the inside?
Inside the garbage disposal where the drain is, I stuck my finger to see what would happen if I plugged it a little bit. It seems to have good pressure when I do that. So there must be something stuck in the hose, Just a guess?
I found that the check valve had some stuff caught on the end of it and inside. Problem fixed!!:D
