ssouthard
#1 Posted : Saturday, August 23, 2008 12:23:52 PM(UTC)
ssouthard
Maytag Neptune gas dryer. When I push the start button the moisture light kind of comes on but the dryer will not start.
libertyappl
#2 Posted : Saturday, August 23, 2008 12:35:28 PM(UTC)
libertyappl
Start by checking your thermal fuse. Test it for continuity. If the thermal fuse is out the dryer will not start.
Part number AP285207(your original one may not look quite like the one pictured.
Hope that helps.
Nat
ssouthard
#3 Posted : Saturday, August 23, 2008 3:28:28 PM(UTC)
ssouthard
My wiring diagram shows a thermal fuse behind the panel and one underneath. we checked the one on top by taking out the wires and connecting the 2, it still won't start. the one underneath seems very hard to get to. if we can get to it, do we check it the same way?
libertyappl
#4 Posted : Saturday, August 23, 2008 5:32:50 PM(UTC)
libertyappl
It's best to check them with an ohm meter. But you can try to bypass the other to see if it will start, but don't run it that way for long, it's for your safety.
Nat
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
