BobbyGreen
#1 Posted : Tuesday, August 19, 2008 8:47:18 AM(UTC)
BobbyGreen
I have a GE Eterna Side by Side Fridge.
ess25lgnaCC model.
Fridge and freezer are hot.
Fridge is getting power.
Interior light is working, Freezer light is intermittent.
No airflow inside freezer or fridge area.
It is not frozen up, removed interior back panel of freezer.
lower fan in bottom back is on and blowing.
compressor does not seem to be vibrating or humming.
Any idea of what I should test / check or replace?
Thanks,
Bobby
abadfish66
#2 Posted : Tuesday, August 19, 2008 9:19:25 AM(UTC)
abadfish66
Do you mean they are hot, or just room temperature, big difference. I would start by checking the main board at the back behind the access cover. Look at the 2 capacitors below the transformer on the top right hand side, are the tops round or look bad compared to the others, Take the board off, and look at the back, do you see any burn marks?
BobbyGreen
#3 Posted : Tuesday, August 19, 2008 9:54:00 AM(UTC)
BobbyGreen
It is outside in a garage in South Florida, so I was hot, but I think that is probably room temp considering the environment.
Looked at the Board.
Nothing on the front looked bad.
On the back there is one solder that looks burnt.
It seems to be going to the black square thing (I think it is a relay, says 12VDC and 20A).
Thanks for the response.
Bobby
abadfish66
#4 Posted : Tuesday, August 19, 2008 9:58:54 AM(UTC)
abadfish66
That spot where it's burnt is the relay for the compressor. So, either you can resolder the relay pin, or get a new board and your problem will be solved.
abadfish66
#5 Posted : Tuesday, August 19, 2008 9:59:55 AM(UTC)
abadfish66
BobbyGreen
#6 Posted : Tuesday, August 19, 2008 10:41:23 AM(UTC)
BobbyGreen
THANKS!!
Resoldered the back of the board and all seems well.
I'll keep the part link in case it goes in the future.
Thanks again,
Bobby
abadfish66
#7 Posted : Tuesday, August 19, 2008 10:44:31 AM(UTC)
abadfish66
Sweet :) glad to help
Angus
#8 Posted : Monday, August 10, 2009 7:20:13 AM(UTC)
Angus
I have the same problem with a GE Profile Artica - Model number PSS26MGPA BB.
Removed the board to find a burn on one contact (also the 12 VDC - 20A). I'm curious what would cause this to burn out. Would it also make sense to replace the PTCR (PTCR RELAY) or overload on the compressor as well?
Thanks,
Angus
Bad solder
#9 Posted : Wednesday, June 8, 2011 4:32:53 PM(UTC)
Bad solder
Originally Posted by: BobbyGreen Go to Quoted Post
THANKS!!
Thanks again,
Bobby
What exactly did you resolder? I have a little burn mark as well where the black relay is attached, but I'm not sure what I'm supposed to do. Did you replace the relay as well? If so, how did you detach it?
Thanks,
Angus
What is the PTCR relay? is it the black box described above with the writing "12 VDC - 20A"?
